Good evening
I wanted to obtain the S-parameters for 3 dual-polarized Vivaldi antennas. I can do this for a few linearly spaced discrete points. I then wanted to obtain the S-parameters for a continuous frequency range. However, after a week and 1000 iterations, the maximum number of sample points was reached and the simulation terminated. Is it possible to continue this simulation and use the frequency data that has already been calculated or does this mean I have to start from scratch and there is no way to use the already calculated frequency data? Does this also mean that the current S-parameters are not correct since the answer did not converge after 1000 iterations?
Regards
Eliz
