🎉Community Raffle - Win $25
Join and Win
Annn file open in hyperview
User: "Rachit Semalty"
Altair Community Member
Updated by Rachit Semalty
Hi all. I am working on an automation project. Currently I am running an NLGEOM simulation whose results are in Annn files. I want to read these files, using hyperview, and then if a condition is met I want to rename them. The problem is that when I try to rename the Annn files I had previously opened, but now closed in hyperview, an error is thrown saying that the file is still open in hyperview. I tried to open a new session in hyperview as well but that too didn't work.
I am able to rename file only after closing the hyperview that I used to open that Annn file. But I don't want to close and open hyperview for renaming Annn files.
May anyone tell me how break the link between hyperview and Annn files without closing hyperview?
Rachit
1 - 1 of 11
    User: "PaulAltair"
    Accepted Answer
    Updated by PaulAltair
    I tried with the model you sent the other day and I can't actually replicate your issue, as soon as I clear the Annn file from HV I am able to do what I like with the Annn files (delete/rename etc), I have  a feeling something changed around version 2020 for this though, I recall it being more of an issue in the past.
    As far as the chain of events goes, there is nothing you can do when running as NLGEOM subcase, the process is controlled by OS subcase, so far as I know, The Annn files are not being converted to .rst, .rs~ or .res though, they go straight from Annn to h3d and are then deleted. The .rst files in the run folder are the Radioss binary restart files, not related to the Annn
    One other suggestion, since you are running a single NLGEOM subcase, could you just do this in Radioss directly? Then you could choose the Anim file frequency or write h3d natively
    Your 0000.rad and 0001.rad that are created in the run folder are your Radioss input files, you could use/edit those as needed?
