Hello, I'm trying mixing with MBD
after I simulate 1 case, i want to change MBD's motion and simulate again.
Can I export last position of MBD from EDEM or motion view.
cause last position of MBD and particle doesn't match from initial position
Hi Junghyun,
It sounds like you're working on a MotionSolve/EDEM cosimulation.
One method of updating a MotionView model with a new position is to export the final position (x, y, and z) for all key points from your model using HyperGraph. Then, you can update the Data Summary Sheet in your model with the new points, and your model will reflect the new position. It helps to have as much of your parent model parameterized as possible with expressions, so there are the minimum number of points that you need to update.
Hope this helps!
Adam Reid
Another option is to add a template to the MotionView model and use the save command.
For example:
<Save model_file = "Restart_1s0.xml" /><Simulate analysis_type = "Transient" duration = "2" print_interval = "0.01" /> <Save model_file = "Restart_3s0.xml" />
What will happen is the model will be saved via xml at that state.
You can also deactivate certain forces after a certain time (let's say the 1 second mark). You can include a Deactivate command.
<span class="- topic/ph ph Blue"><span style="font-family: arial, helvetica, sans-serif;"><Deactivate </span></span>
<span class="- topic/ph ph Blue"><span style="font-family: arial, helvetica, sans-serif;"> element_type = "FORCE" </span></span>
<span class="- topic/ph ph Blue"><span style="font-family: arial, helvetica, sans-serif;"> element_id = "301002"</span></span>
<span class="- topic/ph ph Blue"><span style="font-family: arial, helvetica, sans-serif;"> /></span><br /></span>
What can also be done is the model can be ran again at those saved time intervals.
All you will need to do is create an xml with the load and Simulate command.
Example:
<Command> <Load_Model model_file = "Restart_1s0.xml" result_file = "LOADSAVE_RUN.mrf" anima_file = "LOADSAVE_RUN.h3d" /> <Simulate analysis_type = "Transient" end_time = "3.0" print_interval = "0.01" />
And run that solver script (will need to use the Compute Console in order to do so).
Best,
Christopher Fadanelli
Hi Junghyun, It sounds like you're working on a MotionSolve/EDEM cosimulation. One method of updating a MotionView model with a new position is to export the final position (x, y, and z) for all key points from your model using HyperGraph. Then, you can update the Data Summary Sheet in your model with the new points, and your model will reflect the new position. It helps to have as much of your parent model parameterized as possible with expressions, so there are the minimum number of points that you need to update. Hope this helps! Adam Reid
Thank you for replying.
But in EDEM, MBD showed the different position from MotionView, at that case.
Is it okay? just use position from MotionView?
Thank you for replying. But in EDEM, MBD showed the different position from MotionView, at that case. Is it okay? just use position from MotionView?
Are you stating that the initial position of the MotionView simulation is not the same as the initial position of the MotionView/EDEM cosimulation?
Can you please send any pictures or animations to help explain your issue?
