I would like to export my geometry created in Flux3D to a step format to import it into CATIA.
I saw that there's only a possibility to export it in dxf format.
Please is there a possibility to export it in step format.
Cordially,
To export your geometry into CATIA Format, you need to entered in the modeler context. Using the menu Geometry -> Modeler context.
If the project is solved you have to delete the results before entering in the modeler context using the menu Application -> Delete all project results
I hope this helps.
Best regards.
Cyril Favre
Thank you so much.
Samia
