I'm trying to create multiple base stations consisting of 3 transmitters each, but the program tells me I can only create 12 transmitters.Is it there? How can I solve?Thank you
If upgrading to the commercial version isn't an option looks like you will have to limit the number of base stations or transmitters you have. Maybe you can do 2 separate runs removing one base station in each analysis and then comparing the two results. Or changing some of the base stations to only have 2 transmitters to get under the limit and maybe doing a couple iterations of this with different base stations to see what you get. Hope this at least gives you some ideas for things to try.
Is it possible to combine multiple simulations into a single simulation? because by hypothetically dividing a map into several simulations, the result will not be the same compared to a single simulation with all the transmitters Thanks
First, a little disclaimer, I am by no means a RF expert. So I am just trying to spark some ideas that may help you work with the limitations you have. So if you don't have access to the commercial version I don't think you will be able to run with all 15 transmitters. I was hoping that some of the base stations were separated enough by distance or frequency that you could run a partial model and still get meaningful results.
