Function aborted, Stop calculation? error
User: "Rachit Semalty"
Altair Community Member
Updated by Rachit Semalty
Hi all. I am running a TCL code that needs number of iterations. After a particular number of iterations of one function in the code, hm giving the error:
function aborted, Stop run? yes   no.
I am selecting no and proceeding. The code is working fine. Is there any way I may prevent hm from giving this error or if it may auto select yes so that the calculation does not stop by itself?
Rachit
1 - 2 of 21
    User: "Adriano_Koga"
    Updated by Adriano_Koga
    it's hard to tell what is going on.
    I know that for some user interaction you could use 'hm_answernext' to preset an answer if needed.
    But i don't know if that's the case.
        hm_answernext yes
        *deletemodel
    OP
        hm_answernext yes
        *deletemodel
    Dear Adriano, thanks for your reply. But is there any way I may automatically ask hm to continue? I mean how to catch the error, asking hm to not stop calculation and continue script execution right from where the error occurred?
    I am running a code that involves moving a number of nodes simultaneously. If the number of nodes is small it is fine but when it is more (> 20) the script will give this error after some iterations.
    Rachit
