How to delete settings files
please locate your working directory by right click on hm icon > properties > start in field
In this location delete the hmsettings.tcl, hmmenu.set and command.cmf. also hwsettings.xml
Delete the below files
when I click the "hypermesh desktop" button on my desktop, there is no response. I have installed hypermesh 14 but after running it not getting started nor it is showing any error....
please locate your working directory by right click on hm icon > properties > start in field In this location delete the hmsettings.tcl, hmmenu.set and command.cmf. also hwsettings.xml
There is now a utility in the HyperWorks installation to do this:
C:\Program Files\Altair\2022\hwdesktop\utility\HWCleanup\
Note you will lose your preferences that you may have set. Close the apps before running it.
