Hello Community,
I'm struggling with creating constrained_joint_revolutes. I want to define a rotational movement about the y-axis between two rigid bodies. I know that I have to use the option 'fe joint' to create the joint revolute, but somehow it's not working. There are two pictures attached where you can see the rigid bodies that are necessary for my joint_revolute and how it should actually look like. We are using LsDyna as solver, so the solution has to be compatible with it. It would be great if anybody could give me a step by step tutorial or even better name a book or paper in which an easy instruction can be found. Thank you guys in advance.
Edit: I've already read a lot in the hyperworks manual but without any succes. And google couldn't help me either.
