We installed some strain gauges on a suspension part of a trailer which I need to simulate in Hyperworks.
These strain gauges have a typical size of 6x6mm. I want to represent these strain gauges in my FE-model and compare analysis results with the measurements.
First of all I defined my surface that represents the strain gauge by Geometry > Create > etc. .
After that I used 2D-Automesh to create a fine mesh and created a tetra mesh on all geometry with the option 'match existing mesh'.
Now to my problem:
I need the average strain of all nodes on my 'strain gauge-surface'. I want to use this information to compare this average strain with the measurement results. I have seven node sets which i have to evaluate, so a manual procedure is to time-consuming.
Do you know a tool or an script that is able to do that?
