Hi guys,
I have problem with mass estimation. My model weighs approximately 2x less than it should. I have the data: cab mass+ 'equip'= 760 kg and my model weighs around 300 kg. The problem is that CAD model I received did not have any 'equipment' parts thus I do not know clearly how the rest of the mass is distributed. I am using GRAV card image hence it is important mass matches to the real model (more mass= more inertia load).
My question is how to increase the mass if you do not know how it is distributed?
I have few ideas but I do not know how good these ideas are:
1) I am using only one material. Could I just increase the density of material until I get the final value of mass? Changing density should not affect stiffness or any other behaviour of material?
2) I concentrate the rest of the mass (400 kg out of 700 kg) to the centre of gravity?
Any other suggestions?
Thank you very much.
