Good evening,
I just created a dragged 3d mesh in a solid. Now i would like to edit the amount of nodes on the edge. It seems like this option is only realizable in Quick-Edit for 2D-meshes (By the way: sometimes the editing of density i not possible, why?). So how can i do it on a 3d mesh? And why i cant use all Subpanels from the panel 'edit element' to 1, 2 and 3D? For example i would like to combine elements, but this is just possible on a 2d-mesh, not 3d!
2. Question:
like you see in the following picture the red elements are 3d, the blue ones are 2d. To check connectivity of elements i usually use Tool-> edges or faces. Its obvious, that the red notes of the 3d mesh below does not match completely (different node counts) witch the 3d mesh in the upper solid. To get sure, such things do not happen, how can i check this connectivity?
