*** ERROR # 40 ***
CBUSH # 9099 has zero length.
I have the error message as described above. This is my CBUSH Element and the two nodes which I selected:
https://www.dropbox.com/s/moxwmzopoaq3st8/CBUSH%20Setup.png
I checked that the first node always connects to the dependent node of the RBE3 and that the second node connects to the extra node I created on top of the RBE3 center node.
I once did a workaround with defining a vector so I would not use the default setting for the cbush element as described in the cbush element description. However, I just watched the webinar a saw that he did not and was still able to the CBUSH without that error message.
Where did I go wrong?
Thank you
