Hello Guys,
i want to solve a problem with a bicycle wheel. the issue is a bicycle wheel wich knocks against the edge of a kerbstone.
The plan is to simulate the spokes as ROD elements and the outer wheel as BEAM elements. I created a circle line and on that line i extracted 19 nodes for the spokes. for the middle circle i did the same and connected the nodes with 19 beam elements as shown in the picture below.
Then i created a line mesh on the outer circle and used beam elements. Now i search for a way to connect the spokes with the outer wheel, the rod with the beam elements.
The little rectangle in the lower right corner just represents the kerbstone and is ment as a support thing...it has no elements assigned.
Thanks for the help!
