I like to get a 3D Hex mesh between two parallel surfaces ,
this connection should follow a 180% drill line.
The shown 3D mesh was done with
3D --> line drag
How can I get a 3D hex mesh between the two parallel ends with a 180° drill?
(w/o bounding solid/ surfaces, only with a drag line)
Thanks
P.S. Problem is shown on left side with gap between end - hex and target surface/ mesh
