FAQ 36. How do you create a force along a vector?
Go to Analysis>Forces>create> select the nodes, input the magnitude,Select constant vector and then vecto below magnitude, and choose the vector from the graphics area, now click create.
Hello Rahul,
do you know if it's possible to create forces along a 3D curve? I tried with line load but didn't get the local system for the curve.
Jan
To follow up on that, how should I proceed about setting up a force at an angle? I currently have a force along the z-axis, but would like to offset it by 15 degrees. Is that possible? I have tried the vector feature, but was unable to set up a force that way.
Thanks!
Hi @Ola
Check this video.
