How to set up Boundaries and and Pressure Loads in HyperMesh for an export to Abaqus
Hi,the question is, how you can define loads and boundary conditions in a way, that Abaqus will understand this input.
The easiest way to do this, is to use the Abaqus Step Manager, available in the Abaqus Standard 3D User Profile --> Tools --> Load Step Browser. The video below will explain, how to set up the step, the *Boundary and *DLOAD entries for Abaqus. Please be aware, that Boundaries and Loads will be only exported, if they are defined within an Abaqus *STEP. Please also note, that the Abaqus Input created by HyperMesh can be directly analyzed by the Abaqus Solver and does not need to be read in Abaqus Preprocessor.
http://screencast.com/t/H8Ir2DucpN
To see, in which panel an Abaqus keyword is supported in HyperWorks please see the help, as shown below.
http://screencast.com/t/BMZUycXWn
Kind RegardsJan
