Hello ,
I want to adjust a plane or a component´s face to the axis in system coordinates; how does it work?? in this case the cut plane with the y-axis(see pics).
many thanks in advancenkoelouna
Nkoelouna,
You need to use tool > rotate > select your geometry (surfaces or solids) > select axis of rotation > base point of rotation > input angle of rotation
From your image I see that you need to rotate around x axis with an angle of say 30 degrees
