How to apply hydrostatic pressure in hypermesh
If you want to create a pressure that changes with depth then the best way is to apply the pressure using equation as the load type (click on the arrow next to magnitude in the pressure panel). Example... if surface is at z=0 then to get increasing pressure with depth in water the eqn is rho*g*h = 1000*9.81*(-z)
