Hey Guy´s,
as you can see on the pictures below I´ve got a problem with mehsing the model.
At the yellow colored faces (shared faces which belong to both solids) I created a 2D-automesh. Afterwards I use 'tetra mesh'-panel to create a mesh to all solids.
Hypermesh statusbar says: 'Problem with surface normal orientation'
Do you know whats wrong, e.g. in my model or in the procedure?
