Hi All,
Objective of my simulation is to perform a conjugate heat transfer analysis. I have two solid volumes/ regions and one fluid volumes/region. I would like to mesh all the three and make sure there is a conformal interface between the solid and the fluid volumes. One way to do is at the CAD level, if not I would like to know how to imprint surfaces of two regions on one another and then how to extract just the fluid volume in order to mesh the flow field.
To make it simple, if I have two solids and a fluid flow in between, what is the best way to have a conformal mesh generated for CFD analysis? I have attached screenshot of the domain. Thank you for your help.
Regards
Madhu
