what is the difference between this rbe2 and rbe3 in hyper mesh and when it should be used?I have already seen in help it is just defining both but not comparing it and it's uses.
Please go through this webinar:
http://training.altairuniversity.com/2011/05/using-rbes-and-mpcs-in-radioss-free-recorded-webinar/
As I am doing Thermo-mechanical Analysis, in which I have to use RBE2 for rigid contact element and MPC at the same area (means on the same nodes for incompatible contact) but when I want to run both I got error of
