I have a poblem when meshing a *.stl file with the automesh function at HyperMesh 12.0.
As seen in the pictures below the automesh adds some trias in a wave shape to certain edges, which are not in the *.stl file. It seems like there is a problem meshing some 90° angles.
Here you can find the .hm file with the fnished automesh:
https://gigamove.rz.rwth-aachen.de/d/id/RmUWQLgaAv7exR
It would be nice when someone has some idea/solution how to solve the problem.
Since I am new to Hypermesh a detailed description would be very helpful.
Tim
