how can this parametric file can be made..and IS there any tutorial that shows to make this file.
Hi Syed,
You can toggle the button that says 'parameters file =' using the toggle button to its left, to reveal the use current parameters option,
Use current parameters uses the current default parameter file. You can open and edit this file by clicking the green edit parameter button.
Once the parameter dialog is open enter your required parameters > file > save as > save to a location.
You can then re open this parameter file as necessary using the previous option 'parameters file ='
See image below -
How to use this parameter file, i mean 'what is the purpose of this content with how to use that,and how much of value to give that. if i give any any value,what is reason for changed this geometry'......... this is my question do you have any answer sir???????
