FAQ 31. How to map loads onto different mesh configurations?
You can apply loads to geometrical entities (using forces panel for example) and map them to the FE mesh using the Load on Geom panel.One advantage is that you can remesh a model without deleting complicated loads or boundary conditions. After remeshing, loads or boundary conditions that have been applied to geometrical entities can be remapped to the new mesh. Just click on the relevant load collector and then click on map load
