Hi all,
I would like to build a model like the one in the (low-tech) image attached.
It's 3D, and is effectively a multilayered, asymmetrical domed structure. The materials in each layer are anisotropic, and have axes that are usually parallel/perpendicular to the surface of the object (see drawing). Is there a way to assign material properties that follow this 'curve' to the 3D elements, without having to generate multiple local coordinate systems? My hestitation with multiple local systems is not only the time it would take, but that I don't want there to be abrupt changes in the direction of the properties when moving from one system into another.
The mesh is being imported from an stl file, so there is not a surface/geometry associated with it. I'm prepared to try generating a surface from the mesh if that would help.
Any advice much appreciated!
