Hello
We have a geometry of tubes. How can we create the centre line?
Thanks
You can create this centreline easily in any CAD software.In our script exchange we have script available to do similar thing in Hypermesh.
http://altairhyperworks.in
Hope this would help your problem.
RegardsRahul R
You need to download the script and then run this script from the downloaded location by going to file > run tcl tk from within HyperMesh.
see http://www.altairuniversity.com/support-forum/?mingleforumaction=viewtopic&t=87
you will find this and other scripts in the altair script exchange, go to learning > script exchange from the altair university website or here http://www.altairhyperworks.com/Script-Exchange.aspx?%3ftop_nav_str=1
you will need to log in with your university mail id and login credentials you get after registering to the client centre.
search for the script by just entering centreline in the keyword section.
once you have found the script click on the download button, once you have downloaded the script place it in a convenient location, then you need to do a file > run tcl tk from within HyperMesh. make sure you have a relevant model loaded in HyperMesh when you run the script.
Thank you
It helped me a lot.
