hi,
i have a problem with using symmetry in hypermorph. My model consits of 3D Hex elems which i want to morph in the thickness direction (morph->move handles-> translate-> using elem normals).
I build up the symmetry by creating a system and select it in the symmetry 'sys' with the option '1 plane' and 'align with y-axis', also i selceted all domains and the size. (domains are on one side of the symmetric model).
When i use the option 'enforced' handles are created.
Back in the morph panel i checked the options and the symmetry is active. If I morph, the handles on the symmetric side are moving but not the elems.
I can provide the model if you like.
Thanks for your time!
