I would like to use the BatchMesher to automesh a stl file. However, I always get 'Status=Error: Problem to load model'. I am wondering, if a stl import automesh is even possible with the BatchMesher?
Kind regards,
Tim
Hi Tim,
BatchMesher is a tool that performs geometry feature recognition, cleanup and automatic meshing in batch mode for given CAD files
stl although generated by cad tools is not a cad file or a geometry file, it consists of tria elements and hence the error.
When I convert this stl to geometry using the surfaces from fe option of the geom > surfaces panel
then use this hm file to generate a mesh using batchmesher, giving the criteria and parameter files you had created
batchmesher produces a mesh as shown.
