what does this mapping indicate?and what and when it should be used?
Syed,
This sets how the mesh will be mapped to the surface based on the surface's general overall shape. For instance you will use map as circle for a circular surface or a surface that is close to circular shape, It is best to use autodecide
see HyperWorks Desktop Applications > HyperMesh > User's Guide > HyperMesh Panels > HyperMesh Panels Listed Alphabetically:Automeshing Secondary Panel
