need some tips for loads.
I want to create 3 Forces for each loading condition. I thought about takeing 3 up to 4 Forces into one Loadcollector. I think this is possible- right?
For these Forces I have Points from External References(see Components) I have chosen a point and it was marked, but I got the message:'Points have not been selected' I don't know what this means to me. The point is in the middle of a bolt but not part of the mesh. Is this the Problem?
An other problem is that one of the three points is not inside the moddel (in reality it is but the needed elements are not at the moddle, because I thought that this would not matter.)Is it possibile to create a vecot to this point wich will be extended to the moddle?
A last question: How is it possible to change the specific loads of one load collector in case I haven't created a card edit?
