FAQ 40. How to interpolate pressure loads and apply them using relevant data from a file?
create a file in a text editor and organize load value and location in the following syntaxxlocation ylocation zlocation loadsave the file as .ssvToggle to linear interpolation in the pressures panel,Open this file in the panel and then select the relevant elements from the panel,
