FAQ7. How to create washers on geometry and enter its dimensions ?
Go to Geom > quick edit > washer split Use these controls to create a washer seated on a hole in your model.First specify an offset to determine the width of the washer, and then highlight the line selector and pick the line(s) to which you wish to add washers of that thickness
