Answer:
Generally the clutter data (*.mdb files) can be only used for rural scenario projects.
If you want to use some of the clutter classes as vegetation layer for the urban scenario you can do this by converting the clutter map to a *.veg file, which can be done in WallMan by File => Convert => Vegetation Database. Here you can select the *.mdb and *.mct files and then assign corresponding heights to the vegetation classes in your clutter data (e.g. 10m to forest and 5m to park). Then these heights are saved as pixel data in a *.veg file which can then be considered in ProMan (under the Database tab) as vegetation layer for the prediction in the urban scenario.
