Error 902 CWELD
hypermeshed
Altair Community Member
I try to connect two meshes with connectors to simulate a weld. I have spot connectors with type rod. Then I defined a new property with PWELD and steel as material and assigned it to the connectors component. It is to connect two steel beams.
When I now want to run OptiStruct, I get Error 902:
*** ERROR # 902 ***
Weld uses an ALIGN connection type and
GA (or GB)
is not a vertex grid of a shell element.
CWELD element id = 313472.
GRID id = 63648.
Can someone help me?
Does no one have an answer?
0 -
I have attached a model, where it does not work as well. It is just an example. So it has to do with the setup.
