Which is the best approach using HyperMesh in order to obtain good quality tetra elements (mesh size 6mm) from scanned data and also have a good adherence to scaned data .
I have tried remesh elements and this is not a good solution because I don't have sufficient control of the mesh.
I have tried to create surfaces from FE but the resulting surfaces are not usable for mesh (feature lines cannot be controlled).
Thank you for all suggestions.
Could you try to get better quality STL file? by choosing smaller mesh size for example.
