🎉Community Raffle - Win $25
Join and Win
Copy notes to a different window using TCL command
YannickUser: "Yannick"
Altair Community Member
Updated by Yannick
Hi there,
i have a hyperview session with two windows. In one window i create several notes attached to a geometry and format them using HWC commands. Now i want to copy these notes including its information (entity ID, position etc.) to the other window. I was not able to do so using HWC commands.
Does someone have an idea how to do it?
Thank you :)
1 - 4 of 41
    Hello Yannick,
    th Apply Style is not registered in hwc. Also, you can copy notes but it works only in the native window.
    So my recommendation, if possible, would be to add a loop over windows, so that the notes are created in window 1 then window 2
    Hope this helps,
    Michael
    OP
    Updated by Yannick
    Hi Michael,
    thank you for the fast reply. The notes themselves are created manually in window 1, and I'd like to save that work by automatically copying them to window 2.
    Thanks
    Yannick
    Hi Michael,
    Thanks
    Yannick
    Hello Yannick,
    what about right click -> Apply Style? That should transpose your notes to window 2. You can choose only the entities you want to trapose, eg, only the notes
    Michael
    OP
    Updated by Yannick
    Hi Michael,
    thanks for the idea, I think this will work. But unfortunately it does not track the command in HWC. Do you know the TCL command to do that :)?
    Regards
    Yannick
