Hello Experts
I am using the CFD-EDEM platform to create my debris flow model and its impact on pipes under dam break conditions. I have checked the e-learning tutorial for the introduction and insight into modeling. Further, I need to understand which type of coupling (EDEM-oneway or two-way) is feasible in my case. Also, I need to understand how an interaction will be defined between particle and fluid. kindly share the documentation link to understand the properties required for interaction and if any other tutorial accept fluidized bed using CFD-EDEM coupling
