Good afternoon!
 I'm currently running into an issue with workspaces created after the switch from older versions of Monarch DataPrep Studio. When we moved to Monarch 2023, it seems that null values in analyses are no longer zeroed out. I'm looking to see if theres a better way to achieve this like we used to.
 Its probably easier to explain with pictures..
 Here is an older dash made in an older version of DataWatch Monarch DataPrep Studio
 If you notice, even for disciplines that do not have visits, it returns a zero.
 However, looking at a newer workspace built in Monarch 2023, I'm seeing different behavior.
 To get around this, I'm exporting the summary and re-importing it into Monarch to replace the nulls with 0s,
 Is there an easier way to achieve this in the summary itself rather than having to export something, refresh the data in Monarch, and then re-export the corrected version?
