 Just installed hyperworks 2024 on fedora linux 40 (very similar to redhat). I know it is not supported but I installed the required packages for hypermesh by myself.
 hypermesh runs fine as far as I can tell, but when running hyperview there is segmentation fault, either by running ./hv script directly or changing the interface to hyperview after loading hypermesh.
 Tried with v2023.1, same result - hyperview gives segmentation fault.
 Any experience using fedora, or maybe opensuse, will be helpfull.
 Thanks!
