Hi Everybody,
I am fairly new to Hyperstudy and I would like to use the Stochastic Analysis to investigate the scatter in the linear structural response of a loaded part due to material uncertainty.
I do not want to optimize anything.
Instead, I want to define material constants (i.e. E & Nu) with a mean and a normally distributed upper and lower bounds (e.g. +- 10%).
Then run the analysis and find out how much for instance the Maximum Stress, Strain or Displacement varies for the given load case.
I managed to define the model setup and the variables. The nominal run is complete.
Can I get uncertainty affected vonMises Stresses & Strains as well as Displacements (XYZ) and reacton forces on individual nodes?
These parameters are output variables in the Hypermesh analysis.
However, how can I define these response variables correctly in Hyperstudy?
I am using Hyperstudy 2019 and Optistruct as Solver.
Thanks for your help.
Regards, Sig
