Hello, how can I measure the angular deflection of component that I have analysed using a linear static analysis?
Hi Oliver,
You can measure the angle by selecting the "Relative Angle" option in the Measure tool. I measured the below by picking the node denoted by "1" and then the second node as shown below!
This is in HyperView 2023 version and will be the same in 2023.1 version.
For more Measure tool option, check this link out:
https://help.altair.com/hwdesktop/hwx/topics/panels/measure_tool_create_measure_hvx_t.htm
Thanks,
TL
