I am trying to calibrate my material parameters using EDEM Cal. I can successfully create the calibration jobs by using EDEM Cal. However, when I start to run the simulation jobs using EDEM Cal, I found that all the jobs are finished simulation instantly. I know this is not correct because each job takes a very long time in EDEM simulation. So, when I checked the simulation data, I found that the jobs are accually not be simulated.
I have tried many times but I still do not why the jobs can not be successfully simulated using EDEM Cal. I hope I can get some help from the specialist of EDEM. Thank you in advance!
