I'm trying to create a custom GUI window for a script I'm working on. I can't figure out how to use the selection picked by the user in the HWTK Select List widget. My select list widget is used to select one of the available material collectors in the model. When the user presses the OK button I want to get the ID number of the material collector the user clicked on. How do I do this?
Minimum working example of code attached at "forum_post_mew_selectMaterialList.tcl.txt"
Screenshot of what I'm working with in HyperMesh 2017:
