Hello Team
Kindly tell where is the below shown tools in Hypermesh 2023.Thank you
Sandeep
Hi Sandeep, This functionality is available under 3D menu > Edit Grouping > Solid mesh optimization > 2nd order elements.
Refer the attached image.
Regards
Prajval
Hi Sandeep, This functionality is available under 3D menu > Edit Grouping > Solid mesh optimization > 2nd order elements. Refer the attached image. Regards Prajval
Hi PrajvalThank you for response.RegardsSandeep
