I tried to include dynamic bearing stiffness in a MBD system. The curves were determined by the producer and should be correctly. In the transient analysis I got the following warning:
I think that means, that the curve is not defined in the necessary region. But these high X values (displacement in mm) should never be reached in reality, because the displacement of a bearing is much smaller (factor 100-1000).
When my comprehension is right (the X values in the screenshot were needed), my static system have to be wrong. Am I right with this assumption or is there another mistake?
Thank you!
