I want to use a Bushing between two flexbodies to simulate a bearing.
I have the following error by solving the MBD system:
After that I got the information, that the Bushing has a floating j-marker that is attached to a flexbody. MotionSolve doesn't support it and a dummy-body will be inserted between.
The simulation runs till the end but I don't know if it's the right way ignoring this error-message.
What is the correct way to use a Bushing between two flexbodies?
Thank you!
