I can't run an analysis for this error but I can't find a possible solution. I deleted almost the whole model and left only 1 meshed component and still got that error.
Hi
I cannot understand the source of error.
Do you have the error when using HyperMesh?
Or when running the solver, for instance OptiStruct,?
You can run the model using Altair Compute Console Application, using the model deck exported from HyperMesh as input
I hope this is helpful
Regards
