I'm trying to connect total of three parts like sandwiched together so if I use the tie connection I get the First mode frequency value very high and if I use shared nodes the frequency drop is very noticeable. So I want to know what is the difference between them and what should be used if the center part is acting like a Industrial glue that holds the other two parts?
