I need to define rotor and stator core material. I have received data sheet for steel M800-50A. Inside documentation only what i find usable are this information:
Can i use this value for define core material ? Im not sure wich type of magnetic property to select from this bar ( maybe isotropic analytic saturation (arctan 2 coef.) )
Or i need ask to send me documentation of BH curve values and define the Isotropic spline saturation for example:
Thank you.
Best regards.
