Need to input material properties of Aluminum 6061 -T6 ( or Aluminum Alloy ) . The website https://altairuniversity.com - Material and Property Information provides a PDF of the Aluminum Alloy ( that's okay ) properties in the System m-mm-t-s ( that appears to be the units on the steel when I go to create another material i.e Steel E= 210000 default ) so I'll use those units . However is there a MAT 1 or a data sheet that has the rest G, NU, RHO,A, TREF,GE,ST,SC,SS values in system m-mm-t-s ) This system has tonne/mm etc and not so sure I would do the conversions from SI system correctly. and Google search was not successfully. Need those values in that unit system
FYI
This is my first try at ALtair Hyperworks and it is a student version- Doing on my laptop - at home - retired from engineering profession years ago -just trying to help some student teams -it is slow going with the hardware and internet connections I have
Thanks
